Gallery
Gallery
Aquasport Discussion
240 cc inboard question
Topic: 240 cc inboard question (Read 544 times)
March 21, 2017, 06:45:58 PM
Read 544 times
rmqkslvr83
March 21, 2017, 06:45:58 PM »
I'm looking for some info on prop pitch and diameter for 240 inboard I had lost the prop last season I can't seem to find any write ups or specs obviously because of the rarity any input would be appreciated
March 21, 2017, 07:44:01 PM
Re: 240 cc inboard question
March 21, 2017, 07:44:01 PM »
Welcome aboard!! Did you look in our gallery for info? Not sure if the info will get down to pitch and diameter though. Maybe.
March 22, 2017, 05:30:48 PM
rmqkslvr83
March 22, 2017, 05:30:48 PM »
I did check there have you or anyone ever seen any more information or spec sheets on these boats
March 23, 2017, 07:35:21 AM
Global Moderator
March 23, 2017, 07:35:21 AM »
What year is this hull?
March 23, 2017, 11:24:40 AM
rmqkslvr83
March 23, 2017, 11:24:40 AM »
1974
April 05, 2017, 10:49:05 AM
emptypockets
April 05, 2017, 10:49:05 AM »
i have a 1975 240 inboard "project" also, its tough finding much info on them. Boat is currently shrink wrapped but I have the prop still. Next time I see her I will try to dig it out.
I have attached the info I have found.
April 05, 2017, 10:58:03 AM
April 05, 2017, 10:58:03 AM »
Any good prop shop would be able to recommend a prop based on the boat and HP. In fact they may have a prop loaner program to help you find the right prop. You also need to know your shaft diameter.
April 05, 2017, 07:53:51 PM
April 05, 2017, 07:53:51 PM »
I see you attached the images - if they came from our gallery there is a much easier way to post them from the gallery.
Did you see this folder?
http://www.classicaquasport.com/gallery/showgallery.php?cat=545
May 17, 2017, 09:18:18 PM
rmqkslvr83
May 17, 2017, 09:18:18 PM »
Thank you for ur replys I have a food idea what prop I need I was just curious what it may have came with to compare to mine ......basically to see if I have other problems like down on power, weight if some had changed the motor or trans I don't know much about the history of the boat and it's impossible to find and useful info on them the prop I have is close and I know what needs to be done to get the rpm I need I just didn't want to make changes if it's not the prop that's the problem
