Gallery
Gallery
Capacity Plate
Topic: Capacity Plate (Read 7349 times)
September 19, 2006, 03:54:53 PM
Read 7349 times
Tailgunner
Capacity Plate
September 19, 2006, 03:54:53 PM »
The aluminum capacity plate came off and is gone from my 222. Anyway to get replacements?
Tailgunner
Now in BroadBill\'s hands
September 19, 2006, 04:29:15 PM
September 19, 2006, 04:29:15 PM »
Maybe somebody can take a good close up picture and you can have a trophy shop engrave one for you. Perhaps new 222 owner Joe Vinson has the one from his boat you could copy (see "free 222" in discussion forum).
September 19, 2006, 04:47:27 PM
September 19, 2006, 04:47:27 PM »
OOPS!!!! New owner of the 222 is
hookdup
. Joe's the previous owner.
December 16, 2006, 08:07:12 PM
hunter
capacity plate
December 16, 2006, 08:07:12 PM »
i rebuilt a 86' 170 osprey, and never had the original console can anyone tell me the capacities? Or weights, and limits.
December 18, 2006, 12:00:54 PM
Shine
December 18, 2006, 12:00:54 PM »
Here you go....
http://www.custommarinelabels.com/id1.html
Joel
December 19, 2006, 12:35:12 AM
hunter
December 19, 2006, 12:35:12 AM »
thank you but can some one tell me the capacities so i dont have to get a degree to calculate them.
December 20, 2006, 04:40:30 PM
jdupree
December 20, 2006, 04:40:30 PM »
Hunter,
I had a 1988 170 and my original plate read:
5 persons or 685 lbs
1235 lbs persons, motor, gear
130 hp motor
Hope this helps.
John L. Dupree, III
AQABLA84E999
Member #257
December 20, 2006, 06:05:45 PM
hunter
December 20, 2006, 06:05:45 PM »
Thank you verry much Mr. Dupree. If your ever in las vegas i'll show you some of the best striper fishing in the world!
December 20, 2006, 06:49:17 PM
December 20, 2006, 06:49:17 PM »
I thought you said "Strippers" for a second there
December 21, 2006, 12:39:47 AM
hunter
Reply #9 on:
December 21, 2006, 12:39:47 AM »
Yes "stripers" on lake mead. That is if you were trying to correct my spelling. Probably not as big as the trophy's in the atlantic, but the record for nevada is 63 lbs; that is until I beat it!
January 05, 2007, 11:51:41 AM
jdupree
Reply #10 on:
January 05, 2007, 11:51:41 AM »
Hunter,
Didn't know if you needed a picture of the plate. I am experimenting with photbucket so hopefully I will get it right.
John L. Dupree, III
AQABLA84E999
Member #257
January 05, 2007, 04:12:04 PM
russell1
Reply #11 on:
January 05, 2007, 04:12:04 PM »
I think mine is gone too off of my 69 flatback unless they didnt have one.next ? is do they need one
January 05, 2007, 04:30:03 PM
jdupree
Reply #12 on:
January 05, 2007, 04:30:03 PM »
I couldn't tell you if they are required or not but for $5.00 it would be worth it to me. Especially if you can get your hands on the original weight specifications for the boat. Then it would just be a matter of them printing for you. I guess anything you can do to keep from being boarded by the Coast Guard would be a good thing.
John L. Dupree, III
AQABLA84E999
Member #257
January 05, 2007, 04:33:57 PM
jdupree
Reply #13 on:
January 05, 2007, 04:33:57 PM »
As most of you know, I most likely will be buying a 1982 20' CCP. The capacity plate is faded and not legible. Would anyone out there know what the original number of persons and weight would be for that model? Just thought I would ask :)
John L. Dupree, III
AQABLA84E999
Member #257
January 05, 2007, 05:10:42 PM
Mechanical Master
1982 CCP
Reply #14 on:
January 05, 2007, 05:10:42 PM »
The 1982 models used the number without the dash, so yours would be a 200 CCP. Here are specs on the 1982 200 CCP:
Length: 20' 2"
Beam: 7' 10"
Draft: 12"
Transom: 25"
Weight, dry: 1900 lbs
Capacity: 1800 lbs.
Max. HP: 200
Fuel cap.: 73 gals.
Hull type: Deep V, 20 degree deadrise
The hull was available in two colors: Ivory Mist, and a two-tone Tahitian Tan and White.
Standard equipment included:
- Built-in tackle box
- Dual radio lockers
- Instrument panel with cover
- "Coffin" fish boxes
- Rod racks
- Front anchor locker
- Twin helm chairs
- Live bait well
A fiberglass t-top was an option, and even a tower with dual controls on the 222CCP and the 246CCP.
Capacity Plate
