Actually there's a ton of space in there. If I open up the storage space under the cushion you can see where the hull side and strInger is located. The inside face alone is a big area. I'll have to remove the sink panel one day to see what is in there. Perhaps the original poster can post a pic of inside that area.
I'm pretty certain my water tank sits on top of that "shelf" in your second pic.
Quote from: "wingtime"I'm pretty certain my water tank sits on top of that "shelf" in your second pic.OK then. I had tinkered with the idea of installing a tackle station in that area but the seat pedestal (and the actual seat itself) hampers access from the other side.8 gals. isn't a lot but more than enough for several rinses for a shower or rod/reel wash down.Thanks!
CB,Where is the first pic taken from? and what orientation?
And while I'm at it, why is your boat so clean :alien:
You can get bigger made - I had my 40 custom made and it was pretty cheap.
