Author Topic: 1995 Osprey 200 specs  (Read 3787 times)
May 12, 2010, 08:49:25 AM
Read 3787 times
South Bay
« on: May 12, 2010, 08:49:25 AM »
Can someone please give me the specs for my 1995 Osprey 200
1995 Osprey 200 w/112spl
May 12, 2010, 09:30:27 PM
Re: 1995 Osprey 200 specs
« Reply #1 on: May 12, 2010, 09:30:27 PM »
Quote from: "South Bay"
LOA: 19'-6"
Beam: 7'-6.5"
Draft: 9" motor up/26" motor down
Bridge Clearance 4'-9"
Dry Weight: 1935 lbs.
Fuel Capacity: 56 gals.
Power Rating: 150 hp.
Transom Height: 25"
Dead rise: 12 degrees
May 12, 2010, 09:35:24 PM
« Reply #2 on: May 12, 2010, 09:35:24 PM »
That would be the "someone"... :salut:
May 12, 2010, 09:36:45 PM
South Bay
« Reply #3 on: May 12, 2010, 09:36:45 PM »
Bob,
Thanks for all your help on this and other posts
I really appreciate you taking the time to help
Gerard
April 03, 2019, 03:57:39 PM
Panamax
« Reply #4 on: April 03, 2019, 03:57:39 PM »
Just the info I was looking for.  But, what are the hull materials.
Thread revival...
April 04, 2019, 06:54:30 AM
« Reply #5 on: April 04, 2019, 06:54:30 AM »
Aquasport hulls are solid fiberglass.
July 09, 2019, 01:59:04 PM
outboardsurplus
« Reply #6 on: July 09, 2019, 01:59:04 PM »
I just got a 1988 20 osprey and was wondering the same thing on my boat,any one know.Thanks
July 09, 2019, 03:50:32 PM
« Reply #7 on: July 09, 2019, 03:50:32 PM »
July 09, 2019, 07:51:56 PM
outboardsurplus
« Reply #8 on: July 09, 2019, 07:51:56 PM »
Thanks for the info,but the deal fell thru
July 15, 2019, 09:58:21 AM
arndtb33
« Reply #9 on: July 15, 2019, 09:58:21 AM »
so i just recently bought this boat    replaced my fuel sender    the measured depth is 7 inches  every time is see a post the gas tanks are different sizes   the above says 45 gallons   i have seen 56 gallons   and the physical dimensions are always different   i bought a 7 1/2 inch fuel senders because all specs i read it was 8 inches tank depth  i have got to believe that either mine has been changed  or they came in different sizes?       1995 200 osprey    anyone care to give me some ideas
July 15, 2019, 11:01:40 AM
« Reply #10 on: July 15, 2019, 11:01:40 AM »
Congrats. Reading below and since this thread is for a 1995 200 Osprey, it's safe to assume that is the hull you are addressing.
Since you replaced the sender, it's safe to assume you measured the tank depth correct?
That reference is to an 1988 200 Osprey because the poster piggybacked on to the original 1995 thread. That is why the tank size is different. You factory installed tank was/should have been, 56 gals.
As stated above, your factory tank is listed as 56 gal. Is it a poly tank? Can you see the manufacturer tag/label? It should list tank info (not dimensions) like build date and capacity.
Could it have been replaced? Anything is possible.
Does that model have a removable tank coffin cover (visibly secured with fasteners)?  If not, (deck is solid) it's probably original.
 As to the depth, where did you see that? Since we really haven't seen too many poly replacements (unlike alums) we don't have a lot (if any) resources on the ones Aqua installed.
July 15, 2019, 11:14:09 AM
arndtb33
« Reply #11 on: July 15, 2019, 11:14:09 AM »
so yeah  the 7 inch depth is what throwing me off when i placed measure to bottom of tank  i do not see where the deck has been cut into  and don't see tag    and i found out hard way don't fill tank to brim  so i am going with it original 56 gallons till can figure out  if it has been replaced     i was just hoping that some else has stuck a measure in tank
 and there was 7 also    my first fuel sender was 7 1/2   thinking the tank was 8 inches
July 15, 2019, 11:17:06 AM
arndtb33
« Reply #12 on: July 15, 2019, 11:17:06 AM »
oh yeah why i am asking question what is the best way to prime pump for live well and water outlet    i have replace motor and made sure no obstructions but no water flow     reading where you have to prime the pump?
July 15, 2019, 12:32:29 PM
« Reply #13 on: July 15, 2019, 12:32:29 PM »
Assuming you mean the raw water pick up, is the seacock in the open position?
Common type used on Aquas. Note "arm" (valve) is in open position.
"Hose Bib" style valve
Another style. Note "arm" (valve) is in the closed position.
Probably the type used on your model hull.
https://classicaquasport.com/smf/index.php?topic=13792.0
Good luck. :thumright:
July 16, 2019, 11:28:33 AM
arndtb33
« Reply #14 on: July 16, 2019, 11:28:33 AM »
it is original brass valve handle   i know it opens   i ran a wire thru bottom up about at least 5 foot an no obstructions  i can fell some pressure while it is on trailer when motor is on and my hand over bottom hole  just no water   thats why i was asking about priming it   its got me baffled
