Author Topic: Pictures of Aquasport Capacity Plates  (Read 21676 times)
September 05, 2018, 07:40:08 AM
Reply #60
Re: Pictures of Aquasport Capacity Plates
« Reply #60 on: September 05, 2018, 07:40:08 AM »
New to this site but my 1982 200 CCP is in need of a new COAST GUARD plate and I cannot read a thing off the old one.  Was wondering if anyone has the info off the same model ?    Thanks....Ed.
This is what I came up with for mine.  The specs come from this website, but I had to guess on the person capacity.
September 05, 2018, 01:23:02 PM
Reply #61
jdupree
« Reply #61 on: September 05, 2018, 01:23:02 PM »
Have you actually ordered this one?  If so, can you put me in contact with the place you got it from?  I need one for my 200 CCP.  Thanks!
John L. Dupree, III
AQABLA84E999
Member #257
September 05, 2018, 05:16:48 PM
Reply #62
Hoffmath
Coast Guard Capacity Plate
« Reply #62 on: September 05, 2018, 05:16:48 PM »
Greetings all, I just picked up a 1994 200 in need of some (lots of) TLC. One of the things I don't know how to address is the fact that the Coast Guard data Plate is missing. Any thoughts? Can someone send me a picture of one so I have something on the boat? Thanks Tom
September 05, 2018, 05:26:51 PM
Reply #63
Hoffmath
Re: Coast Guard Capacity Plate
« Reply #63 on: September 05, 2018, 05:26:51 PM »
Sorry, I just realized there was already a thread. I'm specifically looking for a 200 Osprey.
September 05, 2018, 07:04:33 PM
Reply #64
« Reply #64 on: September 05, 2018, 07:04:33 PM »
My plate came from Garzon Studio.  Here's the link: https://garzonstudio.com/boat/capacity-decal.html
I actually found them through a recommendation on Classic Aquasport.  It's the circle of life.
September 05, 2018, 07:55:47 PM
Reply #65
Re: Pictures of Aquasport capacity plates
« Reply #65 on: September 05, 2018, 07:55:47 PM »
There’s a plate for a 196 from deeper into this thread.  The 200 Osprey is basically the same hull.
September 05, 2018, 08:25:54 PM
Reply #66
« Reply #66 on: September 05, 2018, 08:25:54 PM »
https://classicaquasport.com/smf/index.php?topic=9149.msg144608#msg144608
Close enough for government work.
September 05, 2018, 10:28:30 PM
Reply #67
Hoffmath
« Reply #67 on: September 05, 2018, 10:28:30 PM »
Glad I found you-all appreciate all the help. Tom tut
September 06, 2018, 08:35:19 AM
Reply #68
Hoffmath
« Reply #68 on: September 06, 2018, 08:35:19 AM »
I found another site that makes decals that are Aquasport specific: https://outboarddecalset.com/capacity-decals/boat-capacity-decals/aquasport.html
Thanks Again!
September 06, 2018, 12:37:49 PM
Reply #69
« Reply #69 on: September 06, 2018, 12:37:49 PM »
Well technically, the Garzonstudio site is Aquasport (as well as any other brand) specific also in that you specify the boat manufacturer and build location. That stated, you can get decals for either Hialeah built or Bradenton built hulls. Also they are somewhat lower cost.
Not shilling for the site mind you, just stating observations.
Good luck. :thumright:
July 25, 2019, 06:11:17 AM
Reply #70
outboardsurplus
« Reply #70 on: July 25, 2019, 06:11:17 AM »
I was reading about the different plates and was wondering if there is any way to bring back the the plate where you can read it.I have a 1982 osprey and the plate is there just can't read it
July 25, 2019, 09:18:47 AM
Reply #71
« Reply #71 on: July 25, 2019, 09:18:47 AM »
The older (Hialeah) hulls were a metal plate. Newer ones were "mylar" type decal. Never seen one brought back. Sun damage/corrosion usually pretty much renders the plate/decal unrestorable, hence when someone has a readable original, we ask they post a photo. That way a new decal can be created, for those who wish one for their rebuild/restore.
July 25, 2019, 05:08:03 PM
Reply #72
outboardsurplus
« Reply #72 on: July 25, 2019, 05:08:03 PM »
Thanks,mine is a metal plate
May 01, 2020, 08:33:37 PM
Reply #73
AquaWilly
« Reply #73 on: May 01, 2020, 08:33:37 PM »
Hi.  Like many others my cap plate is unreadable, so I want to have a new one made.  Looking for the plate specs for an early 80s 22-2 FF O/B.
1981 22-2 FF
1979 Johnson 150 V6
May 02, 2020, 07:39:59 AM
Reply #74
« Reply #74 on: May 02, 2020, 07:39:59 AM »
You may not find a readable plate from that era but like several of us, you can back into most of the data that apears on the plate with a little searching.
Here's a start.
You know the manufacturer and that it was built in Hialeah Fla. You have the max HP. You will have to "guess" the max weight and passengers but your hull is very similar to a CCP but with a different cap. I would tend to use that.
Something like this for a start. You can search the Gallery section also for more documentation.
AXIMUM CAPACITIES
9 Persons or 1200 LBS.
2000 LBS. Persons, Motor, Gear
245.0 H.P. Motor
This boat complies with US Coast Guard safety
standard in effect on the date of certification
Model: 222 CCP O/B              AQUASPORT, INC.
                                         HIALEAH, FLORIDA
Design Compliance with BIA Requirements Below is
Verified: MFGR. Responsible For Production Control
Load and HP capacity/Level Flotation/Steering and Electrical System
Compartment Ventilation/International Lights
Certified BIA (emblem)      National Marine Manufacturers Association[/i]
[/quote]
