Author Topic: Pictures of Aquasport Capacity Plates  (Read 21658 times)
June 06, 2015, 06:20:14 PM
Reply #45
Re: Pictures of Aquasport capacity plates
« Reply #45 on: June 06, 2015, 06:20:14 PM »
Here is a link to images of capacity plates that we received from Aquasport.  Can you copy it and take it to a printer for replication - not sure.
http://www.classicaquasport.com/gallery/showgallery.php?cat=766
August 25, 2015, 07:54:09 AM
Reply #46
« Reply #46 on: August 25, 2015, 07:54:09 AM »
Very interesting. :ScrChin:
Hull is a 1993 210 Explorer
On closer examination the plate is stamped for a "230 Walkaround".
Might have been left over from a batch circa 1991 when they were still labeled WACs or just an outright "oops".
December 18, 2015, 11:03:37 AM
Reply #47
Georgie
« Reply #47 on: December 18, 2015, 11:03:37 AM »
Here's the plate from my 246 CCC which also reads as if it's a 246 FF.
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
December 18, 2015, 12:44:03 PM
Reply #48
Re: Pictures of Aquasport Capacity Plates
« Reply #48 on: December 18, 2015, 12:44:03 PM »
That's weird. Apparently the capacity is the same though.
March 20, 2016, 11:41:15 AM
Reply #49
Aquamaniac
« Reply #49 on: March 20, 2016, 11:41:15 AM »
Here is a pic of my 1973 170's plate:
Max HP 130 (surprised me!)
Max persons 795 (also surprised me....a crowd or a few whoppers!)
Max capacity persons,motor,gear 1575 (that 90hp four stroke is a chunk of that!)
 :drunken:
April 05, 2016, 07:32:59 AM
Reply #50
Callyb
  • MidWest
Looking for a picture of an Osprey 245 Capacity plate
« Reply #50 on: April 05, 2016, 07:32:59 AM »
I searched and searched, but came up empty... I would appreciate, if anyone has a pic of one, to post it please. I have a 1997 model that needs a new one made.
Thanks,
Carl
___________________________
April 05, 2016, 09:38:04 AM
Reply #51
Re: Looking for a picture of an Osprey 245 Capacity plate
« Reply #51 on: April 05, 2016, 09:38:04 AM »
As close as I can get.
July 23, 2017, 05:52:17 PM
Reply #52
THE SHADOW
« Reply #52 on: July 23, 2017, 05:52:17 PM »
Edit:
Taken from member "Wayne'sWorld" post 8 Nov. 2009:
Here is the exact wording, line by line, on the capacity plate.  The AS is an '86:
MAXIMUM CAPACITIES
9 Persons or 1200 LBS.
2000 LBS. Persons, Motor, Gear
245.0 H.P. Motor
This boat complies with US Coast Guard safety
standard in effect on the date of certification
Model: 222 CCP O/B              AQUASPORT, INC.
                                         HIALEAH, FLORIDA
Design Compliance with BIA Requirements Below is
Verified: MFGR. Responsible For Production Control
Load and HP capacity/Level Flotation/Steering and Electrical System
Compartment Ventilation/International Lights
Certified BIA (emblem)      National Marine Manufacturers Association
Hello
New owner of a 222 ccp of 1988, I count that my boat does not have plate of capacity ...
After research, I followed this thread ... and I am perplexed in front of this track.
9 people on this boat ?? ... seriously ??  :shocked:
January 10, 2018, 09:20:14 PM
Reply #53
Sergdm86
Metal person capacity weight
« Reply #53 on: January 10, 2018, 09:20:14 PM »
Hello everyone, i have an 86 aquasport 250xf, just bought at the end of this past summer... I was wondering if anyone knows how to purchase the metal capacity weight or people for the boat. The one on there now is unreadable, and i am not an experienced person. This is all new to me. Any help would go a long way. Thank you all
January 11, 2018, 05:32:18 AM
Reply #54
Re: Metal person capacity weight
« Reply #54 on: January 11, 2018, 05:32:18 AM »
See if you can find what you need in this topic, then you can get one printed locally.
https://classicaquasport.com/smf/index.php?topic=9149.0
January 11, 2018, 01:48:59 PM
Reply #55
« Reply #55 on: January 11, 2018, 01:48:59 PM »
OK,
I merged your thread with the one listed in Rick's link. If you want to replace your capacity plate then you either need a photo of a member's plate with your model Aqua or get somewhat creative. Then you can order a reproduction made. This repo will be vinyl rather than metal but will do the same thing.
A quick search of the thread linked (this thread you're reading) doesn't show an exact match for your year and model so let's get creative.
What we know:
86 XF tells us the Manufacturer is Aquasport Inc. and was built in Hialeah Florida.
Model 250XF can be found in the Photo Gallery under Documentation. Let's see.
We see max HP is 300
Now, browsing the thread we find this:
Click this link.
https://classicaquasport.com/smf/index.php?topic=9149.msg83579#msg83579
This is for a Genmar 250/Osprey/EX but is close enough (IMHO) to your XF hull (CCP hull with XF cap) that you could use the remaining info on Persons 8 1200 lbs 4300 lbs Persons, Motor, Gear
Now you have enough info to create your sticker which you will do here.
https://garzonstudio.com/capacities-decal/4x3-b.html
There ya go. All of this is in this thread but hey, first one's always free.
Good luck :thumright:
January 14, 2018, 01:48:34 PM
Reply #56
Sergdm86
« Reply #56 on: January 14, 2018, 01:48:34 PM »
Thank you so much Capt. Bob!!
May 16, 2018, 07:44:54 AM
Reply #57
Hunthard
« Reply #57 on: May 16, 2018, 07:44:54 AM »
just picked up a 1994. 20ft cc osprey.  haven't seen the capacity plates can anyone tell me what it should be.
boat has a yami 150. thanks.
May 16, 2018, 08:08:05 AM
Reply #58
« Reply #58 on: May 16, 2018, 08:08:05 AM »
Comparing your hull specs with various models, this is as close as I can get.
HP capacity is correct and the hull weights are similar. You can make it anything you want but these numbers will be close.
Good luck. :thumright:
September 05, 2018, 05:10:59 AM
Reply #59
82aqua200ccp
« Reply #59 on: September 05, 2018, 05:10:59 AM »
 New to this site but my 1982 200 CCP is in need of a new COAST GUARD plate and I cannot read a thing off the old one.  Was wondering if anyone has the info off the same model ?    Thanks....Ed.
