Rickk, Bob, Wing...def like to hear your thoughts
My hull is in original layout w/manual steering. I'd really like to install a hydro jack plate w/4" setback. The issue I'm picturing is when the engine raises so does the steering cable (along w/engine harnesses, fuel hose, etc). And this cable runs in the starboard trough w/removable deck lid. So as the engine and cable go up its gonna lift open the lid...then on way down the lid will not close flush w/deck. Am I correct?
If so, I reckon this means only way I'm installing a jack plate is if I run all engine to console connections under the deck??
