Engines & engine woes
225 Johnson ocean runner vro or premix
Topic: 225 Johnson ocean runner vro or premix (Read 823 times)
July 13, 2018, 10:45:34 PM
Read 823 times
joe b graham
July 13, 2018, 10:45:34 PM »
I have a 1995 225 Oceana runner what do y’all recommend keeping the vro or premix the gas?
July 13, 2018, 10:51:45 PM
Re: 225 Johnson ocean runner vro or premix
July 13, 2018, 10:51:45 PM »
Absolutely keep the VRO. They are very reliable.
July 13, 2018, 10:55:54 PM
July 13, 2018, 10:55:54 PM »
BTW in 1995 it is no longer VRO it is an updated system called Oil Metering System (OMS). Here is a light read for you:
http://continuouswave.com/whaler/reference/VRO.html
July 14, 2018, 07:46:47 AM
July 14, 2018, 07:46:47 AM »
Agree.
The motion to remove the oil injection comes up here (and on every other forum dealing with boats and motors) every so often. If it's broke, fix it. If it works, keep it.
Good luck
July 22, 2018, 07:26:52 AM
Levi
July 22, 2018, 07:26:52 AM »
I don't know about the newer vro but my mechanic told me to delete it on my 1992 225 VRO because it wasn't IF but WHEN the VRO let go that it would blow the powerhead before I could realize it was bad.
July 22, 2018, 07:46:10 AM
July 22, 2018, 07:46:10 AM »
Urban myth.
It will however fail, like anything else on an outboard, if it isn't maintained/inspected on a fairly regular basis.
July 22, 2018, 09:53:55 PM
July 22, 2018, 09:53:55 PM »
Time for a new mechanic. 1992 is second generation VRO, very reliable. #1 as long as your alarms are working... you'll know if the VRO fails (unlikely) #2 if in the unlikely event there is a failure the usual failure mode is to inject MORE oil. #3 if your alarms are not working your more likely to blow the motor up by overheating it.
Make sure the carbs are clean and burn good gas... that thing will run forever.
September 01, 2019, 07:09:55 PM
September 01, 2019, 07:09:55 PM »
Would one recommend adding the VRO back that was removed by the previous owner?
- Ulysses
1974' 240 CC -
1970’ Flatback 222 -
1981’ Osprey 22-2 -
1971’ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
November 05, 2023, 01:33:21 PM
Scode68
November 05, 2023, 01:33:21 PM »
YES!
2001 Osprey 215 Sport
