Gallery
Gallery
22-2 Rebuilds
1976 22-2 rebuild, factory inboard to outboard conversion
9
10
11
12
15
Topic: 1976 22-2 rebuild, factory inboard to outboard conversion (Read 12562 times)
April 20, 2020, 05:31:53 PM
Reply #135
Re: 1976 22-2 rebuild, factory inboard to outboard conversion
Reply #135 on:
April 20, 2020, 05:31:53 PM »
Cool on the paint. Have you picked colors?
April 21, 2020, 02:05:17 PM
Reply #136
theFunsmith
Reply #136 on:
April 21, 2020, 02:05:17 PM »
I think I am going to go with a white to match the truck. I think it'll be a good looking package, and white is a color that never goes out of style on a boat.
June 02, 2020, 04:32:35 PM
Reply #137
theFunsmith
Reply #137 on:
June 02, 2020, 04:32:35 PM »
Been spending the last bunch of days attacking the last of the underside hardware spots from the old prop shaft, support, rudder and thru-hulls, as well as redoing a previous beaching-rash repair. And sanding. Lots of sanding. I have a pretty substantial hook to address, I will start laying up some 1708 and epoxy tonight to start correcting it. With any luck I will be ready to start filling and long blocking this weekend.
June 02, 2020, 04:43:29 PM
Reply #138
Reply #138 on:
June 02, 2020, 04:43:29 PM »
Great call on flipping the boat. All that would have been a nightmare to do on your back.
June 02, 2020, 05:41:25 PM
Reply #139
Fishhead
Reply #139 on:
June 02, 2020, 05:41:25 PM »
Awesome job, love those scuppers!!
19-6 family fisherman
24 osprey pilothouse
22-2 family fisherman
June 02, 2020, 06:46:43 PM
Reply #140
Reply #140 on:
June 02, 2020, 06:46:43 PM »
Taking the hook out brings back bad memories of a lot of work
June 03, 2020, 01:16:25 AM
Reply #141
theFunsmith
Reply #141 on:
June 03, 2020, 01:16:25 AM »
Quote from: Fishhead on June 02, 2020, 05:41:25 PM
Thank you sir.
This evening I buttoned up the rudder and support patch and smoothed out the quickfair on the gouges and other glass laid from yesterday. I ran out of steam before I got the hooks filled but thats next on the list.
June 03, 2020, 01:45:07 AM
Reply #142
Reply #142 on:
June 03, 2020, 01:45:07 AM »
Nice work, and by work, I mean a lot of work!
June 03, 2020, 07:42:08 AM
Reply #143
Global Moderator
Reply #143 on:
June 03, 2020, 07:42:08 AM »
I want to see the crane again.
June 03, 2020, 11:16:13 AM
Reply #144
theFunsmith
Reply #144 on:
June 03, 2020, 11:16:13 AM »
Quote from: Capt. Bob on June 03, 2020, 07:42:08 AM
I anxiously await the day. Once the paint is down, I will be making an appointment.
June 03, 2020, 12:32:56 PM
Reply #145
Reply #145 on:
June 03, 2020, 12:32:56 PM »
I am having a discussion with myself on that flat spot of the aft bottom and how that is going to make the boat handle. When she was an inboard there was a drive shaft, prop, and rudder to break up the flatness. Now you don't have that. If you look at a regular 12 degree semi-V bottom, the "V" went all the way back to the transom.
Is there a plan to build that up to complete the V?
June 03, 2020, 03:59:01 PM
Reply #146
Fishhead
Reply #146 on:
June 03, 2020, 03:59:01 PM »
Looks like the bottom of my 24 osprey, they designed it that way to create lift
June 03, 2020, 05:43:12 PM
Reply #147
Reply #147 on:
June 03, 2020, 05:43:12 PM »
I think your Osprey was newer ('92/93? - the special 230 Osprey) and had a 18/19 degree hull instead of his 12 degree hull (like my '92 Explorer - totally different hull). Could make a difference in turning performance, like a flat back and slide around on a turn.
Something to think about and discuss here.
June 03, 2020, 08:34:04 PM
Reply #148
Fishhead
Reply #148 on:
June 03, 2020, 08:34:04 PM »
Sorry rick, I meant my osprey pilothouse ( Washington boat) I’m sure funsmith knows them well lots up in his parts
June 03, 2020, 10:44:04 PM
Reply #149
theFunsmith
Reply #149 on:
June 03, 2020, 10:44:04 PM »
That pilothouse unit is a very close keel profile. I had considered extending the V to the transom, but opted not to. The V in the keel extends a good ways back as it is, and I am betting the added effort wouldn't show in performance but I could be wrong. Unlike a flatback, the last 24" or so on mine is still 12° with the exception of 4" of flat. I cant imagine that ~1/2" of added V height would ever help me nail a turn I was going to miss otherwise. I am no fluid engineer, however, and if I am missing the mark now would be the time to change course.
9
10
11
12
15
22-2 Rebuilds
