Aquasport Discussion
Need some advice on 222 Osprey
Topic: Need some advice on 222 Osprey (Read 395 times)
April 07, 2020, 01:54:50 AM
Read 395 times
Daslayer443
April 07, 2020, 01:54:50 AM »
Bought the boat this past summer and it’s in fairly good condition. My only issue is that the rear floor is soft from behind the leaning post (right behind the gas tank coffin) and then the step down section to the transom. I’m looking for the best and easiest fix and don’t really know where to begin as seasons right around the corner hopefully and i want to get it fixed. I also have some minor chips out of the gunwale underside that I need to fix. I plan to repaint/gelcoat floor as well as console and then continue my way around the hull. It seems most of the damage was caused by improper sealing of hatches in floor as plywood is damp. Everything else still looks good. I am installing a large 9-24 hatch behind leaning post but would still feel comfortable with some ideas on fixes and support.
Rebuild with repair will come shortly after. For now I must get ideas as I am overwhelmed and just need answers.
I’m really looking at section repair as an option more then full deck as it seems that those are the 2 places affected by this issue and I’d like to keep it that way.
Pictures will come asap when I remember to take them hopefully tomorrow.
April 07, 2020, 06:49:01 AM
Re: Need some advice on 222 Osprey
April 07, 2020, 06:49:01 AM »
You could do epoxy injection.
https://classicaquasport.com/smf/index.php?topic=14122.msg140281#msg140281
April 07, 2020, 08:57:11 AM
Daslayer443
April 07, 2020, 08:57:11 AM »
Honestly.... that was my thought but I wanted to see what the forum would give me for info before I started drilling haha.
April 07, 2020, 09:04:39 AM
April 07, 2020, 09:04:39 AM »
If you do a cutout and patch, it'll be hard to tie the patch into everything without a ton of fairing to finish it. And as you said, it's only temporary anyway.
April 07, 2020, 09:12:33 AM
Daslayer443
April 07, 2020, 09:12:33 AM »
Yeah, I’d rather do this and then rip everything out later when I have the time and be able to do the whole boat at once. Thanks, just ordered epoxy so hopefully it comes soon. Been taking advantage of the bad times to really get work done on this boat.
May 13, 2020, 12:37:20 PM
May 13, 2020, 12:37:20 PM »
Hey man, It looks like we are in a similar situation with similar boat. Have you decided on a repair methodology? I have one soft spot on my 222 Osprey and the same chips under the gunwale. Where are those photos!!? ;)
1974' 240 CC -
1970’ Flatback 222 -
1981’ Osprey 22-2 -
1971’ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
March 29, 2022, 02:57:26 PM
Daslayer443
March 29, 2022, 02:57:26 PM »
I went with the injections on my boat. Will be doing flood hopefully next year after this season. Took it out last season and wasn’t thrilled about how much water comes in scuppers so I will need to go to the drawing board on that whether I raise floor level a little or put self closing ones.
March 29, 2022, 04:40:27 PM
March 29, 2022, 04:40:27 PM »
What year and model is the hull?
1974' 240 CC -
1981’ Osprey 22-2 -
