Author Topic: 1970 aqua sport 22-2 complete rebuild advice  (Read 434 times)
March 29, 2018, 08:58:18 PM
Read 434 times
Floridaboyadv
« on: March 29, 2018, 08:58:18 PM »
I have just acquired a 1970 222 and am wanting to do a basic rebuild. I am an inshore guide and am wanting a basic fishing boat. First off I’m cutting the floor deck and console out. From what I can tell the stringers are still in great shape. The boat has been taken care of really well and is completely stock. First question is what do I need to do to install a 60 gallon below deck fuel tank?  Next question is what are the pros and cons to enclosing the transom? Next Porta Bracket vs bobs action series? Then who makes consoles with towers attached for the boat?  I’m new to aqua sports but have always wanted a no nonsense guide boat that is functional and easy to work on. Thanks
March 30, 2018, 03:50:22 AM
boatnamesue
  • Jason
Re: 1970 aqua sport 22-2 complete rebuild advice
« Reply #1 on: March 30, 2018, 03:50:22 AM »
When you pull the old tank out take its dimensions (if it's also a 60g). If it's smaller than a 60g then you'll need to take measurements of the coffin.  If 60g poly tanks are available in the dimensions you need then you'll have choice of poly or AL.  If they don't offer poly in your dimensions then AL is your only choice.  If you use AL, search threads here for the modified pascoe method of installation.
The only con I know of when enclosing the transom and adding setback with bracket is the most likely event of moving the COG aft.  This will cause performance issues, as AS's naturally sit low in the rear.  However, you're removing the deck, thus you'll be able to move the fuel tank forward to compensate for the added aft weight.  I'm a fan of the porta bracket, personally.
Console/Tower new is a custom built job.  If you're a guide then I assume you live near coastal waters, so you'll have numerous choices on who to hire to do the fabrication.
Jason
1976 AS 170
1998 S115TLRW
March 30, 2018, 10:10:30 AM
northfork
« Reply #2 on: March 30, 2018, 10:10:30 AM »
You could check with Panga Marine for console and tower
